JD440 transmission wanted
bitcoder
Post by bitcoder » Tue Jan 11, 2011 8:39 pm
Bought a JD440C in pieces, started on the transmission, but on close inspection, the gears have worn through the hard surface, so looking for a complete unit, would like a 5 speed, but 4 speed is fine, thanks for any leads.
bitcoder
Post by bitcoder » Wed Jan 12, 2011 8:27 pm
i'm not sure, is this a measurement of the outside diameter of the gear?
Floyd Fulton 805 624 9921
Post by JD440ICD2006 » Wed Jan 12, 2011 9:09 pm
There is only one ring gear if it has the GM 2-53 engine. (440ICD) You need the larger tranny.
Contact me if you need specific info.
bitcoder
Post by bitcoder » Sat Jan 15, 2011 8:24 pm
hi Ralph,
have you had a chance to inspect the 5-speed transmission?
Floyd
