JD 350 won't move.
gregjo1948
JD 350 won't move.
Post by gregjo1948 » Mon Jan 10, 2011 11:03 am
I'm looking at a 350B diesel with a reverser that doesn't move either direction. It makes a noise toward rear tranny/rear end. Makes the same noise in all gears and forward or reverse. Any ideas? Thanks Greg
JWB Contracting
Coupler
Post by JWB Contracting » Tue Jan 11, 2011 10:13 pm
I had a similar problem and it turned out to be the coupler between the tranny and reverser. Lots of labour to fix as you need to pull the engine and reverser to get at it.
Just a thought..
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
switchhappy
Post by switchhappy » Wed Jan 12, 2011 11:12 am
if it is the cupler, its best to go at it form the rear, take out the rear end, its not that bad, just my 2 cents
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
JWB Contracting
Rear Entry
Post by JWB Contracting » Wed Jan 12, 2011 2:52 pm
We didn't go that route as our 350C's are widepads, then you have to mess with outside bearings, axles, etc. We really get at it and we started at 7AM and by noon we had pulled the motor, loader assembly and reverser. Fairy fast with two guys, althought it took a better part of a day to reassemble.
Jason Benesch
Post by Paul Buhler » Thu Jan 13, 2011 6:13 pm
I once had the same problem with the machine in the middle of nowhere. We had a dozer rather than a bucket loader, so we built a tripod, pulled off the canopy, nose and engine with a chain hoist followed by the reverser. Had the reverser rebuilt in a JD shop, and re-assembled the machine in reverse order. A lot of levering and some lifting and cursing to do, but the project was more time consuming than difficult - of course it rained on one of those days just to add to the fun. The machine was spread out on the ground, and looked pretty forlorn. I had experienced help during the reassembly so every thing was aligned carefully and torqued to spec so that there were no issues with shucking (loose connections) while the machine worked in its next life. I worked the machine two more years before trading it in on a larger 450c. Good luck. Paul
Users browsing this forum: No registered users and 302 guests
