93A Repair Kit
bonker81
93A Repair Kit
Post by bonker81 » Fri Jan 07, 2011 2:26 pm
I was going to rebuild the outrigger cylinders on my 93A but I see uncle Deere wants $141 for a rebuild kit each?!?! that seems obscene. What am I missing that they can get away charging that for the kit. Is there some special material or component?
Lavoy, do you carry these? Any where else to find them? I figured rebuilding a cylinder would cost $20-$30 per cylinder.
1970 350 with a 93A backhoe attachment
Post by Tigerhaze » Fri Jan 07, 2011 4:55 pm
I can't speak to this specific kit, but Deere's prices can be substantially higher than other aftermarket sources for the identical part. It's the price for being "green" :wink: :lol:
DBCSteve
Re: 93A Repair Kit
Post by DBCSteve » Fri Jan 07, 2011 9:21 pm
bonker81 wrote:I was going to rebuild the outrigger cylinders on my 93A but I see uncle Deere wants $141 for a rebuild kit each?!?! that seems obscene. What am I missing that they can get away charging that for the kit. Is there some special material or component?
Suggest trying brokentractor.com, although I have not checked for your specific rebuild kits myself. I got rebuild kits for the blade cylinders for my 450C. Brokentractor charged $45 per kit, JD charges $170 -- and they were embarrassed to tell me that high price (they probably don't sell a lot at that price).
Steve (450C rebuild now complete, and I'm pushin' down trees!)
JD 450C, Serial No. 316559T
Kubota L3400 top-n-tilt
bonker81
Post by bonker81 » Mon Jan 10, 2011 8:12 am
Would the local hydraulic shop carry the components? Is there something special about "Deere" cylinders?
MattE
Post by MattE » Mon Jan 10, 2011 8:53 am
Reliable aftermarket parts.
Greatest place for seals and cheap.
www.rapartsinc.com/
Nisse
Post by Nisse » Thu Feb 10, 2011 1:20 pm
I bought seals for my JD400 backhoe here:
http://www.epm.com/john_deere450.htm
Good price, good service
Nils
JD400A Backhoe
Post by digitup2 » Thu Feb 10, 2011 7:18 pm
If Lavoy can't find you parts I use Hercules BullDog for parts here is a number for you !-800-777-5617 I have the numbers for you code-PV8 rod size1 3/4 bore size3 1/2 and Deeres number is JD-RE1875419 the1995 price is 45 bucks I use these seals on all my equipment and they are as good or better than origional It says all 93-93A-9250 and9550have the same part#Digitup.
gerald
Post by gerald » Thu Feb 10, 2011 9:23 pm
If lavoy don't have the. I use crawer Heaven , nice dude to talk with. http://www.crawlerheaven.com/contactus.htm
Post by Lavoy » Fri Feb 11, 2011 8:58 am
Local hyd shop should have everything you need on hand, or easily available. I can check here, but not likely any cheaper.
bonker81
Post by bonker81 » Fri Feb 18, 2011 12:09 pm
I ended up using Fox Prints out of Maine. Good service, great price, good on the phone.
Users browsing this forum: NevadaKid and 213 guests
