2010 crawler tach
jhv1050
2010 crawler tach
Post by jhv1050 » Thu Dec 30, 2010 2:05 pm
Looking for info on the tachometer on a 2010 crawler diesel, I have not been able to find on through deere dealer. Will any other deere Tach work in this crawler?
Pammark
Post by Pammark » Sat Jan 01, 2011 9:17 pm
You did not mention any part numbers. I have a 2010 diesel with a parts manual. I bought the tach cable at the local JD dealer without any problems. Here are the part numbers in question.
Tack - AT 17449T (it does not specify gas or diesel, must be the same)
Cable - AT 15470T for serial numbers to 42000
AT 17504T for serial numbers after 42000
You can try the JDParts website or contact your local JD Dealer for any cross-reference with wheeled tractors too. Then you can try a tractor junkyard if you knew what models to look for.
If you need a good tractor junkyard, there are several in Ohio I can recommend with phone numbers. Try ebay too.
JD 2010 Crawler with Loader
2010OWNER
2010 tach
Post by 2010OWNER » Sun Jan 02, 2011 8:50 pm
I have a 2010 crawler and a 2010 tractor. If you just want to know the RPM's, any 2010 tach will fit. The tach on my 410 backhoe is a different diameter (smaller). I suppose it could be made to fit with an adapter plate.
B.
'63 2010 Dozer, '44 Model B Tractor,'65 2010 Tractor, '55 40c crawler, '77 2240 Orchard Tractor.
JAY AND EBBEN
Post by JAY AND EBBEN » Mon Jan 03, 2011 11:02 am
try looking on johndeereparts.com
We're not bottom feeders, we're salvage experts!
Re: 2010 crawler tach
Post by Tigerhaze » Mon Jan 03, 2011 11:34 am
jhv1050 wrote:Looking for info on the tachometer on a 2010 crawler diesel, I have not been able to find on through deere dealer. Will any other deere Tach work in this crawler?
You may want to check out these posts:
http://www.jdcrawlers.com/messageboard/ ... tachometer
RanchTruck
Post by RanchTruck » Sun Jan 30, 2011 11:52 am
You can also use any aftermarket gas tach by gluing two magnets to the crank pully and making a bracket to hold a crank trigger. Set the tach to 4 cylinder mode (2 pulses per crank rotation) and that will give you the most accurate reading you can get.
Users browsing this forum: No registered users and 213 guests
