350 dozer losing trans fluid
joe k
Post by joe k » Tue Aug 10, 2010 5:12 pm
Need help where oil is going. Dozer starts right up but when put in gear, oil is leaking into the motor. I believe the dipstick on the right side by the brake pedal is trans fluid and the dipstick on the left side by back left heel is reverser oil. The dipstick on the right side empties out into the motor. Is there a pump or seal that can be bad that is leaking back into motor? It is a 1978 JD dozer.
KenP
Post by KenP » Wed Aug 11, 2010 4:38 am
deleted
drf1232000
Post by drf1232000 » Sun Aug 15, 2010 2:58 pm
hello, I'm new to a JD 350 and to this board. I'm also in need of a little help. If The dipstick by your right foot is the reverser oil level and the
dipstick by your left heel is the transmission oil level. Is this also where you fill with oil? What type of oil do you use in each???
Thanks for any help
Dwight
Will trade electrical work for help with JD350 repair work
Dwight Flemming
KenP
Post by KenP » Sun Aug 15, 2010 5:22 pm
deleted
Post by digitup2 » Sun Aug 15, 2010 7:06 pm
Got a trany cooler on the oil filter? that is the first place I would look .Digitup.
gerald
Post by gerald » Tue Aug 17, 2010 6:32 pm
Thats funny I didn't know there was oil check by the left foot and the right foot would be reverse. On cat its the trans on the old skider and jd 303 oil ok answered question i posted early .Thank you Kenp
