219 or 239
219 or 239
my 450c jd has a 219 will that flywheel fit a 239 w/o balance shafts it will bolt on but will it through it out of balance need some help!!!
Look up both part numbers and if they are the same then install it .I would not knowingly install a wrong harmonic ballancer on anything as the money saved verses money spent could easily come back as an other motor job there are small things different in the two blocks and the crank and it's harmonic ballancer are probably two of them .A used one at a tractor wrecker's can't be too expensive shop around If the rest of the motor is scrap the ballancer should still be good there should be one out there cheap .But look up those part numbers.If you buy one sell your old one on e bay people will buy anything on there!! Digitup.
Users browsing this forum: No registered users and 273 guests
