Wanted: R.H. foot rest 440 crawler
BKahler
Post by BKahler » Fri Jan 27, 2006 7:24 pm
I'm in need of the right hand foot rest for a 440 crawler. The diesel and gas versions are the same. Not sure if any other models will fit, maybe Lavoy can answer that one. The part number is T10453T.
Thanks,
Brad
lastchancegarage
floor tin
Post by lastchancegarage » Fri Jan 27, 2006 11:33 pm
Brad, Unfortunately you're a couple of days too late. A guy on ebay is parting out a 440 and had the 4 pieces of floor tin for auction. :cry:
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
BKahler
Post by BKahler » Sat Jan 28, 2006 8:44 am
I saw that auction and was going to have my wife bid since it ended while I was at work. Unfortunately she got distracted by her boss at the last minute and forgot. :cry:
I hardley ever win an auction where I bid early so I always bid one time at the end. I either get it then or else someone else valued it more than I did.
Thanks,
Brad
lastchancegarage
maybe another source
Post by lastchancegarage » Sat Jan 28, 2006 9:03 am
Brad, I know the feeling of getting distracted at the last minute and missing an auction. There is a guy in Buffalo NY that recently tore down a 440 to component level. :( I emailed him about some stuff he had left over. I can ask if he has any sheet metal he might have thought wasn't valuable enough to put on auction. :D If he's still got it, I'll grab them for you. Keep plugging away on the crawler. Talk to you later.
BKahler
Re: maybe another source
Post by BKahler » Sat Jan 28, 2006 9:24 am
lastchancegarage wrote:Brad, I know the feeling of getting distracted at the last minute and missing an auction. There is a guy in Buffalo NY that recently tore down a 440 to component level. :( I emailed him about some stuff he had left over. I can ask if he has any sheet metal he might have thought wasn't valuable enough to put on auction. :D If he's still got it, I'll grab them for you. Keep plugging away on the crawler. Talk to you later.
That would be great :lol:
Ebay's a great resource when you use it right. One other item I'm also looking for is the curved guard that goes over the track adjuster. Have one, need the other.
Thanks,
Brad
lastchancegarage
foot rest
Post by lastchancegarage » Mon Jan 30, 2006 6:37 am
Brad, Unfortunately it sounds like all the small stuff is gone. :( As far as the curved shields go, if you have access to a sheet metal brake and a lolly column you should be able to fabricate one(or two). If you need the gage of the sheet metal I can get it of my machine. I already snapped the first bolt trying to get mine off. I'm going to try the Kroil on the others. If you need all the dimensions, let me know.
BKahler
Re: foot rest
Post by BKahler » Tue Jan 31, 2006 5:59 am
lastchancegarage wrote:Brad, Unfortunately it sounds like all the small stuff is gone. :( As far as the curved shields go, if you have access to a sheet metal brake and a lolly column you should be able to fabricate one(or two). If you need the gage of the sheet metal I can get it of my machine. I already snapped the first bolt trying to get mine off. I'm going to try the Kroil on the others. If you need all the dimensions, let me know.
Scott, thanks for checking. I find I am also in need of the top and side baffles for the radiator. I was looking through the parts book and realized I didn't have to remove those when I pulled the radiator, because they weren't there :(
Also missing are the guards for the governor.
If you or anyone else could provide sketches with dimensions I could probably have the local sheet metal shop fab them up for me.
Thanks,
Brad
Post by Lavoy » Tue Jan 31, 2006 9:43 am
Brad,
I think I found my governor guard, what part number are you looking for?
lastchancegarage
dimensions
Post by lastchancegarage » Tue Jan 31, 2006 11:24 am
Brad, If the rain stops by the time I get home, I'll get those dimensions to you. Should be an easy job for a metal shop. Talk to you later.
BKahler
Post by BKahler » Tue Jan 31, 2006 4:32 pm
Lavoy wrote:Brad,
Guard # AT12025T
Cover # AT11894T
These are the governor side cover & top cover.
Thanks,
Brad
BKahler
Re: dimensions
Post by BKahler » Tue Jan 31, 2006 4:34 pm
lastchancegarage wrote:Brad, If the rain stops by the time I get home, I'll get those dimensions to you. Should be an easy job for a metal shop. Talk to you later.
Anything you can come up with would be great!
Thanks,
Brad
lastchancegarage
various sheet metal parts
Post by lastchancegarage » Thu Feb 02, 2006 10:33 pm
Brad, Sorry for the delay, my quicky vanity change downstairs turned ugly. :x Anyway, here's some pics of those parts you were asking about.
The angle of the plates matches the frame and grill contour. They look to be 1/4" thick plate. You'll have to measure up the hole placement. If you can get some transfer punches, I've had good luck with them.
Sheet metal is about 3/32" thick, 5.5" high at center and 8" wide at base (inside measurement) with 1" flanges bent out on each side.
The governor cover looks pretty involved. Here are some pics to get an idea. Hope this helps.
If you need actual dimensions for the various mounting flanges let me know. It'll take a little while but I'm sure I can put something together for you.
Hope all this helps.
BKahler
Pictures
Post by BKahler » Thu Feb 02, 2006 10:44 pm
Wow :D
Thanks for the detail pictures. Now to print them out and draw up some plans to fabricate from.
I'm hoping Lavoy has the governor guard for sale. That would save me from having to make that piece at least.
Thanks again!!!!
Brad
Post by Lavoy » Fri Feb 03, 2006 10:13 am
Brad,
I found the guard, and it is like the one pictured above. By part number, the one you need is different. The part number you gave me is for the late 440, this cover is for early.
BKahler
Post by BKahler » Fri Feb 03, 2006 8:23 pm
Lavoy wrote:Brad,
I think the serial # of my crawler is 459125 (I'll double check that). Looking at the parts book and comparing the photos above I'm sorry to say you're right, the guard that should be on my crawler looks a lot different. Dang :cry:
Foiled again.....
Thanks,
Brad
