JD 420C
J Bouchard
JD 420C
Post by J Bouchard » Thu Jan 26, 2006 6:51 pm
Is it possible to repair a 420 sprocket with a ring with the teeth on a sprocket that is worn , or is it necessary to buy a new sprocket?
Post by Lavoy » Thu Jan 26, 2006 7:18 pm
There are no 1 9/16" weld on rings available.
J Bouchard
420 sprocket
Post by J Bouchard » Tue Jan 31, 2006 10:23 am
In that case, the only way to repair a worn sprocket is to replace with a new one? or can the be welded up and repaired with some grinding of the worn teeth. Is there a jig for such a repair job? John B
