jumping out of gear
lp14255
jumping out of gear
Post by lp14255 » Tue Jun 01, 2010 8:23 pm
my 350 wont stay in second gear. if you put it in second gear and move the shifter forward into drive it pops out of gear? why, the fulid level is good.
1969 jd350 crawler dozer
Post by Lavoy » Wed Jun 02, 2010 8:22 am
Most likely bad bearings and or gear.
Post by mini kahuna » Wed Jun 02, 2010 6:52 pm
I did have a case backhoe jumping out of gear and it ended up being a loose shift fork......now a 350 has a different type shifter setup,Lavoy is right,sloppy bearing or chipped out gear.
lp14255
Post by lp14255 » Sun Jun 13, 2010 9:42 am
what has me puzzled is when its in second gear, the gear that it jumps out of, putting the reverser in forward its jumps out , but when the reverser is in reverse it doesnt jump out , it drives fine.
Post by Lavoy » Sun Jun 13, 2010 11:04 am
That is likely because the gear is tapered. In reverse, it is running on the flat part of the gear.
lp14255
Post by lp14255 » Sun Jun 13, 2010 11:16 am
ok thanks , i guess just need to take the cover off and see whats wrong.
john.
lp14255
Post by lp14255 » Tue Apr 12, 2011 11:44 am
after waiting forever for nice weather , i finally took the trany cover off and found that the second and reverse sliding gear ate up pretty bad along with the cluster gear. well guess i'm going to have to replace the bad gears.
Post by digitup2 » Tue Apr 12, 2011 11:55 am
Check to make sure that the shift gates are timed as well .If your shift pattern doesn't stop in the right spot every time they will eventually pop out of gear.Digitup.
gerald
Post by gerald » Wed Apr 13, 2011 4:42 am
digitup2 I have question what gear would ya recommend running a 350 crawer with bucket moveing dirt I stay in frist gear most of time just started useing second it's faster. Would firts gear be earser on the machine? Im no operator.
lp14255
Post by lp14255 » Fri Apr 15, 2011 6:41 pm
lavoy do you have the second gear and cluster gear for the 350
Post by digitup2 » Fri Apr 15, 2011 9:56 pm
I havent put time on a gear driven dozer for so long now I have several old gear driven crawlers but never have time for them .All we put hours on now are hydrostatic but the old rule of thumb was 1st for hard bangin at it then 2nd for the major work then 3rd for the light stuff and 4th for long run movin around onlyDigitup.
Post by Lavoy » Sat Apr 16, 2011 4:41 pm
GIve me part numbers if you can, but pretty sure I have them.
lp14255
Post by lp14255 » Mon Apr 18, 2011 7:24 pm
second gear # t16326 , cluster gear # t16598 , and your price for each . thanks.
Post by Lavoy » Mon Apr 18, 2011 8:01 pm
Both are good numbers, I need to double check on availability.
lp14255
Post by lp14255 » Wed May 11, 2011 7:55 pm
the cluster gear has alittle wear on the cornners it from the second gear rubbing against it, should i replace the cluster also
Users browsing this forum: No registered users and 266 guests
