Undercarriage parts common to a 450 and a 550 dozer?
emkothe
Post by emkothe » Tue May 25, 2010 7:38 pm
I am trying to figure out what, if any, parts are common between a 450 and 550 undercarriage? I could post some part numbers from my 550 manual if someone has a manual from a 450 to compare to. I found a 450 locally being parted out.
I need all the wear parts, but am also missing the front shields and the inner and outer shields on the lower rollers. I presume these are important, but missing on my machine.
Mark
OneWelder
Post by OneWelder » Thu May 27, 2010 2:24 pm
Bottom track parts on 450-C serial # 216303 and up the same as 550 as far as I know
emkothe
Post by emkothe » Fri May 28, 2010 7:50 am
OK here are the PNs from the 550 manual that are in question. The top list are wear parts, the next 2 are parts that are missing. Last is the frame rails. I think I can straighten them, but if I can buy straight ones cheap I would.
Just trying to avoid a long drive if they are not going to fit.
Any help appreciated.
Mark
AT56689 - Track chain, 36 link with headless master pin
T42835 - Sprocket
AT31129 - Carrier roller
T21221 - Shaft for Roller above
AT36391 - Adjuster piston
T20700 - Adjuster Yoke
Lower roller guards
AT18541 - Outer LH and Outer RH rock guard shields (near bottom rollers)
AT79598 - Inner LH rock guard shield (near bottom rollers)
AT79599 - Inner RH rock guard shield (near bottom rollers)
Front idler shields
T30136 - Upper front RH & Upper Rear LH
T30137 - Upper Front LH & Upper Rear RH
T21225 - Lower LH
AT18834 - Inside upper
T21224 - Lower RH
AT77627 - Frame RH
AT77629 - Frame LH
Users browsing this forum: Google Adsense [Bot] and 257 guests
