440 Reverser
lastchancegarage
440 Reverser
Post by lastchancegarage » Fri Jan 20, 2006 7:44 am
The 440 I have has a shaft down by the clutch pedal but no linkage or connections of any kind hooked up to it. It doesn't look like there was a shifter installed either. Was the reverser housing and shaft installed on all 440's? I'm wondering if I in fact have a reverser or I'm looking at some sort of a "dummy" shaft which has no internal working parts. The shaft slides easily back and forth but doesn't feel as though anything is engaging inside. Any info would be appreciated. Thanks.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
Howard Yoder
Post by Howard Yoder » Sat Jan 21, 2006 4:46 pm
the reverser was an option but some people when they went bad put a dummy shaft in them istead of repairing them. Lavoy can anser you better when he comes back he's like a walking dictionary on these things.
Post by Lavoy » Sun Jan 22, 2006 6:59 pm
Howard is correct. Look in the front bung plug and will either see a clutch pack, or nothing but a shaft, I am betting on the shaft.
fishhawk
Post by fishhawk » Tue Jan 24, 2006 6:21 pm
so if there is just a shaft in there insted of a clutch pack are there still bearings that need lubing? i might be dumpung in oil for nothing!
Post by Lavoy » Tue Jan 24, 2006 8:11 pm
If it was done correctly there is not. They should have removed the rear clutch pack and drive hub, as well as the front idler bearing.
lastchancegarage
nothing but the shaft
Post by lastchancegarage » Thu Jan 26, 2006 10:15 am
You were right Lavoy, nothing but the shaft left in there. One more thing to fix when I get ready to tear it down.
Users browsing this forum: No registered users and 207 guests
