Craig
40C picture
40C picture
Heres a picture of our 40C as it is. As you can see the decals appear white and the trackgear hs been painted Cat yellow. The blade is very interesting and it must have been altered as I have never seen a JD blade like this one.1
Craig
Craig
- DiggerLarry
- Contact:
It is a good crawler. Thanks for the HU on the decals as I really was thinking they were white. The blade has hydraulic tilt and three manual angle adjustments. I used it to do a driveway and it was just the cats behind when it came to cutting a watercourse and then making the whole thing lay over on an angle.DiggerLarry wrote:Over time, those decals will bleach out white, I guess from the sun but I've seen that many times. Not sure about the blade, can't see it all. Is that some unused brackets on the back of it?
That should make you a nice crawler.
Now I need to get the engine running a bit better. She's missing quite a bit and doesn't accelerate smoothly. Suspect the ol carb is in need of a few pieces.
Craig
