420 carb flooding?
420 carb flooding?
Any ideas why carb is getting a steady flow of fuel? Fuel coming out of breather tube at carb.
- JD440ICD2006
The float inside the bowl opens and closes a needle valve that controls the amount of fuel in the bowl at any given time. It can be a bad needle valve, a bad needle valve seat, or the float not adjusted correctly.
A new needle and seat are included in most carb rebuild kits.
Usually this turns out to be a piece of dirt stuck in the needle valve. That means a manual cleaning.
There's supposed to be a screen inside the carb inlet, part of the elbow that the fuel line attaches to. They get clogged, and I've seen a lot where someone just snipped off that screen as a result.
So, now the dirt it used to trap gets to the needle valve and - stick city with gas wandering out of the air intake.....
Later!
Later!
- Paul Buhler
- Paul Buhler
whoops, use pm or send to: pbuhler@vermontel.net.
