Caterpillar D2 repair
fixedforever
Post by fixedforever » Fri Apr 09, 2010 9:45 pm
Ok, I just got the Cat D2 for $300. I am trying to get it working. Does anyone know any place where I can get parts for this machine? I need a distributor cap for the pony engine.
Here are some pictures of it, I should have taken pictures of winching it on the trailer to get it home, it was interesting.
1010 Gas Crawler sold
2010 diesel crawler loader
shinnery
Post by shinnery » Fri Apr 09, 2010 10:20 pm
Have you tried www.amoc.org or www.antiquecaterpillar.org or crawler heaven? The first two are caterpillar websites.
Post by Lavoy » Sat Apr 10, 2010 8:31 am
I can get some new parts, not sure how much.
fixedforever
Post by fixedforever » Sat Apr 10, 2010 9:49 pm
Ok, it seems the engine is seized. I tried putting it in 5th gear and towing it with my 1010, the engine turns about an inch then stops. I am going to try and remove the injectors and pour penetrating fluid in the cylinders, let it sit, and then try towing it again. Is this the best way to free up this engine?
And Lavoy, I need one of the spring contacts in the distributor cap that rides on the rotor. Its a very tiny piece.
Post by Ray III » Sun Apr 18, 2010 5:49 pm
Can't get a breaker bar on the crankshaft?
pop pop
busting that engine loose
Post by pop pop » Thu Aug 12, 2010 12:45 am
make a concoction of penetrant, oil,pantherpiss,gas, what ever you got,
and pour it right down the stack , at least 2 quarts,
it will go the same way the rain went.
then turn that crankshaft back and forth till you get about half a round,
pull injectors, see which runs out with the most crude,
"lather, rinse, repeat"......
one thing to keep in mind, SERIOUSLY, you will have an explosive mixture under compression if you crank it too far
KenP
Post by KenP » Thu Aug 12, 2010 4:18 am
deleted
Willyr
Post by Willyr » Thu Aug 12, 2010 7:16 am
I always took the starter out, using a crowbar on the flywheel teeth one can slowly work the engine over.
I am with Ken, using your other dozer to turn it over is asking for truoble. Unless you wanted to do it rough and dirty.
former owner of a 1956 420c
