350B Waterpump rebuild
JonND
Post by JonND » Tue Apr 06, 2010 11:19 am
I am planning to dig into the waterpump on my 350B and I am wondering if there are any tips to make this job easier. The fan/pump shaft is loose, woobly, leaks coolant and occasional binds up. I was planning on purchasing the seal kit, gaskets and bearing shaft assembly. Is there any thing else to be concerned with? Any tricks with pressing the seals, impellar or pulley in place? The manual is fairly descriptive.
Thanks much, Jon
mikeintn
Post by mikeintn » Wed Apr 07, 2010 7:05 am
I just did mine , just be careful and dont break your front pulley, I couldnt get anything behind it to press it off, so I made a puller out of 1/2 in. plate drilled 4 small holes for where the fan bolts 1 bigger hole in the middle and welded a nut on it, used a bolt to push against the shaft, it worked good for me.
Dont forget to order the 2 small seal and or plastic pieces that goes on back of impellar, and be careful not to press the impellar back on to far, its easy done. hope this may help some, good luck :D
Michael
tuney443
Post by tuney443 » Sun Apr 11, 2010 7:25 pm
Actually, your friendly JD dealer can do this for you extremely cheaply and in hardly any time at all.I was amazed how quickly and cheap mine was done a few years ago.
Found the skull to the mastodon in Hyde Park, youngest one ever found so far in the world in 2000.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
Users browsing this forum: No registered users and 261 guests
