440 brake crank arm/lever rocker arm movement
lastchancegarage
Post by lastchancegarage » Fri Jan 13, 2006 6:07 am
I went to the John Deere Operators Manual (OMT73459) to see if I could adjust the steering clutches. When I opened the covers, it looks as if the lever rocker arm and the brake crank arm are locked together. :shock: The brake adjusting set screw really does nothing for the moment. I ended up backing off the brake band adjusting nut to gain a little more steering on the right side. :D Has anyone run into this before? If so, any ideas on loosening the two arms? Thanks.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
Post by Lavoy » Fri Jan 13, 2006 9:41 am
If they are badly rusted, you will probably have to pull the final. Otherwise, try soaking it with penetrating oil and get them moving.
