Could anyone tell me were the Reverser Filter is located on a 350C with shuttle shift.
Thanks,
Tom
JD 350C Reverser Filter
BSims66173
- 420 crawler
Underneath the crawler. looking from the right side through the track, just above the belly pan, you will see a cover with four bolts holding it on. take these four bolts out and the cover will come off. The filter is attached to that cover. Be aware that removing this cover without draining the reverser will allow all the fluid to run out. Best to drain the reverser before changing the filter.
Reverser Filter
Many thanks for your support and information.
Regards,
Tom
Regards,
Tom
Users browsing this forum: No registered users and 234 guests
