2010 steer clutch,,help
tractormandiggerdozer
hi, do not have book w/me. been workn in s.ok and brought dozer down from mi.,,, worked good long time,,, need to fix steer clutch,, any info helps,, we pulled track off... ?? don't know if we need to take final drive apart or what,,, kinda get me started and i can probly get it.
hemiracing
- 40C crawler
2010 clutch
I did both of my clutches last fall here is what I did.I did not remove final. I pulled tracks, removed sprockets,there is a three bolt cover that goes over pinion to remove. Take off the inspection plate over clutches, unhook brake and remove top casting of clutch house. Go back to pinion and with slide hammer pull pinion out. The center of pinion is threaded but I cannot rember size 3/8 course I think and this is what you attach slid to. I few taps and it will come out. After that everything comes out and in through clutch housing. Mine went real good so I hope you have the same luck. I have a book so if you get stuck yell and I will try to help....Paul
Users browsing this forum: No registered users and 68 guests
