Im in need of the small plate the temperature sensor threads into that mounts on the back of the head on my 2-53 diesel. Part #5123352, Small, football shaped, bolt hole on each end and a threaded hole in the middle for the temp sensor. Seems mine has a crack just below the temp. sensor opening. Suppose I could make one if I had to but thought Id see what is out there. Thanks for any help!
(330)416-4613
Small Plate Needed for My 440 Diesel Motor
- dr.fireman10
- 420 crawler
JD 430C 40V 420S 430S 430W 430T 435 630S
