mikeintn
Post
by mikeintn » Sat Feb 27, 2010 2:02 pm
My radiator on 350B has a bad oil cooler in it, water from radiator runs through it, local radiator shop says they cant fix it, a new radiator from Deere about 1500
thats not good, does anyone know of anything that would be wrong with pluging the hoses and just using it for a radiator and useing an external oil cooler, and what size cooler do you think it would need?
Michael
KenP
Post
by KenP » Sat Feb 27, 2010 4:27 pm
deleted
KenP on Sun May 26, 2013 4:44 pm, edited 1 time in total.
mikeintn
Post
by mikeintn » Sat Feb 27, 2010 6:18 pm
You make some good points KenP, the cooler may need to be as big as the radiator, I went to 2 shops they talked like they couldnt get a cooler, it was made in the tank, and if they took it apart they would have to put a new core in it, so looking for a used one maybe a good idea or I maybe able to find one thats bad that would have a good tank- cooler on the bottom, it is a dozer.
Michael
KenP
Post
by KenP » Sat Feb 27, 2010 6:44 pm
deleted
KenP on Sun May 26, 2013 4:45 pm, edited 1 time in total.
bdcz
- 420 crawler
Post
by bdcz » Thu Mar 11, 2010 11:37 pm
I got my radiator on my 350 completely recored for $350. Just like new and much cheaper than a new radiator. I found the shop by asking my local dozer mechanic who he used.
mikeintn
Post
by mikeintn » Fri Mar 12, 2010 9:00 pm
Thanks everyone, I found a used one
Michael
Post
by digitup2 » Sat Mar 13, 2010 8:47 am
Keep that old rad you should be able to rebuild it even with a leaking cooler core in it .If you don,t have too many core tubes damaged or the tanks damaged it is a repairable unit and you could sell it on here.Digitup.
Users browsing this forum: No registered users and 109 guests
