440 IC Upper Track Roller Replacement
Scott Corbett
Post by Scott Corbett » Mon Feb 15, 2010 4:00 am
Replacing both current track roller-base plate assemblies.
Do not have the 1" spacer blocks under the rollers, now.
Replacement rollers came with 2 spacer blocks.
Any comments on the need to install spacers or still leave out?
Not planning any track adjustments, currently plenty of sag to accomodate the extra 1" or so.
Not sure why they are needed?
John Deere 1959 440IC Loader
Post by Lavoy » Mon Feb 15, 2010 2:12 pm
Put them in, that was an update for the older crawlers, the later ones used a taller support.
Post by Stan Disbrow » Mon Feb 15, 2010 3:32 pm
Downward sag leads to faster pin and bushing wear. They must have decided that there was still too much sag, and so lengthened the idler supports as a running change. The blocks would be to do the same with the shorter supports....
later!
Post by Lavoy » Mon Feb 15, 2010 3:36 pm
If I remember the service bulletin correctly, there was not enough pressure on the upper idler so it would quit turning and wear a flat spot on it. I have the bulletin around somewhere, but who knows where.
Users browsing this forum: No registered users and 263 guests
