JDCrawlers picture hosting instructions
Locked
JD40c
Post by JD40c » Sun Apr 17, 2005 9:45 am
****UPDATED 12/10/2006****
Image hosting for the JDCrawlers messageboard has a new home. It works exactly as it did before, but it is now hosted on the jdcrawlers website.
To upload photo's, head over to http://www.jdcrawlers.com/uploads/upload.php
I have set up a picture hosting server as a trial to see how it works out. If you would like to try it, head to http://www.jdcrawlers.com/uploads/upload.php and try it out. After uploading an image, it will show you the code to use to actually display the image. Please limit any picture uploads to crawler photo's only!
An example would be the following:
Code: Select all
[img]http://www.jdcrawlers.com/uploads/plowing_snow2.jpg[/img]
***will display the following***
All you need to do is click the button labled Img above the text window, paste in the URL for your image (whether it's hosted on the JD Crawlers server or not) and then click the Img button again. You'll note that if you don't close the code, the button will look like Img*. The * means that it knows you need to close the code.
Locked
