royboy
- 420 crawler
Post
by royboy » Wed Oct 28, 2009 10:38 am
I am rebuilding a 2010 crawler... after removing the sleves I found a hair line crack in the block between two of the cylinders
and it runs down to the main shaft...
So, would like to fine a block... Any ideas??????
Thanks,
RoyBoy
Fort Madison, Iowa 52627 319 372 3529
- Site Admin
Post
by Lavoy » Wed Oct 28, 2009 4:36 pm
That might be tough, that is a common complaint. Friend of mine has 4 blocks, 3 of them have cracks there.
Rockpig
Post
by Rockpig » Wed Oct 28, 2009 4:36 pm
HI, we are all but in the same boat, apart from i'm in England and you in USA.
I have a couple numbers of places over your way that have helped us out no end for parts for the 2010 crawler.
1, PB&H equipment
Antrim new hampshire
1- 603-588-3005 (thanks to Andrew for passing me this number)
http://www.dierjdparts.com/ Here is a link for (Ted) in Canada, also very helpful.
Hope this helps you out a bit?
Ali
JD430C
Post
by JD430C » Wed Oct 28, 2009 4:44 pm
Good luck finding one, I gave up after a few months and bought a complete engine. IF I find one I will let you know.
Andrew
claude murwin
- 420 crawler
Post
by claude murwin » Wed Oct 28, 2009 6:43 pm
gas or diesel ? I should still have a diesel outta 2010 wheel tractor
1010 dozer,750,dozer,2010 tractor,ac d17,vac case
royboy
- 420 crawler
Post
by royboy » Thu Oct 29, 2009 8:35 am
A big THANKS to all for the info on finding a block... I will check out the links and make some calls... It is a diesel engine... and I am learning a lot doing this myself... Hope it runs someday?????
Thanks again...
royboy
Stretch
Post
by Stretch » Thu Oct 29, 2009 5:21 pm
I have two 2010 diesel blocks if your interested.
2010C Dozer, 2010C Loader
Rockpig
Post
by Rockpig » Fri Oct 30, 2009 4:04 pm
Stretch wrote:I have two 2010 diesel blocks if your interested.
HI, how much are you after for 1?
Were in process of stripping ours down. Not sure if we need one as we will get it checked out first.
Stretch
Post
by Stretch » Sat Oct 31, 2009 6:13 pm
I don't know what a block is worth, make an offer.
Users browsing this forum: No registered users and 218 guests
