1959 440icd
I ripped off the front mounting plate for my hydraulic pump.
I broke the casting that mounts onto the front of the Detroit 2 cyl.
Lavoy, do you have one of these?
it appears to just mount to the front of the motor.
The front hydraulic mounting plate has a few bolts that go into it this piece to attach it to the front of engine
I would take the plate, and bracket if you have it. They both were castings.
Do you have one or both?
anyone?
parts needed, mounting plate, and more
Scott in wa.
no luck yet
Got a couple people searching there inventory, but no luck on this part yet.
I may find out tomorrow.
it looks like they make no change (or they make no reference to ) from the gas to the diesel, but there was a break in the serial numbers, mine is a late model.
so If anyone can find one please let me know.
I also would like to find the hydraulic valve controls for a 831 loader.
the tilt power down is leaking a bit, I did put ne o-rings in there but they are in to bad of shape, so the bucket drifts. anyone go this? loader control block?
soon it will be raining and I will be stuck digging power trenches with the 51 hoe, in the mud again..
Scott in wa.
