rusted bolts
gus
rusted bolts
Post by gus » Thu Sep 24, 2009 5:03 pm
What is the best way to remove rusted bolts?? My steering clutches look rusty and the bolts are small and look like they will twist off quite easily :oops:
I'm going slow to eliminate future problems. :lol: :lol:
gus
Post by gus » Thu Sep 24, 2009 5:43 pm
I've been looking at my clutch problem.. :? Seems that JD engineers saw fit to place the bolts close enough that a 6 pt socket won't go on.
One I tried wanted to round over. I'm considering welding a nut on top that I can get to. Also the heat from the weld should loosen it up a bit.
This can't be a new problem, so how did you fix it??
They've only been in there for 50 years or so :lol: :lol:
Lowly
Post by Lowly » Thu Sep 24, 2009 5:45 pm
Heat does wonders! If you think of it before you twist off the bolts you're way ahead of the game. Someone recently showed me that if you draw a bead of weld around the inside of a bearing race they will all but fall out when they cool. It's just like magic.
gus
Post by gus » Fri Sep 25, 2009 11:53 am
Well the rusty side is done and none twisted off. I did have to weld nuts over the top to hold onto. My Sears open ends wanted to spring too much. I ground the nose down on a box end so that I could slip it under the tip of the bolt sticking through the nut. That gave me enough grab to get the job done. Some frog wizz overnight might have helped a bit too.
Post by Lavoy » Sat Sep 26, 2009 3:58 pm
When you put it back together, put lock washers under the bolts, that will help a lot. Most people, myself included don't remember to do this.
Users browsing this forum: Majestic-12 [Bot] and 12 guests
