440icd Steering Clutch Installation
jac
Post by jac » Sun Dec 11, 2005 1:02 pm
First of all, Lavoy, the parts arrived. Thanks
Now the fun begins. Starting to reassemble the machine. However, I never took the throw out bearing cam and quills apart to clean and inspect them. They seem to work fine and I am going to replace the springs and replace the throw out bearing. Any thoughts on whether I should take everything apart since I am working on them anyway?
jdman
Post by jdman » Mon Dec 12, 2005 10:37 am
Take Them Apart..... Clean And Inspect Them And Grease And Re-Install....... The Little Time You Spend Now Will Assure You There In Good Shape... And If Something Goes Wrong Later You'll Kick Your Self For Not Digging Deeper..... Just Think If You Have To Tare It Apart Again!!!!! Remove Track, Sprocket, Final Drive, Ect. Lots Of Work..... I Have Tried The Short Cut Before And It Always Comes Back To Haunt You.....
Jeff
Post by Lavoy » Mon Dec 12, 2005 11:37 am
I would echo everything Jeff said, including the tried the shortcut way.
jac
Post by jac » Mon Dec 12, 2005 4:45 pm
My thought also. Started taking apart the bearing carrier and can not get it off that thin sleeve. Gets hung up at the very end, likely due to slight damage to the sleeve. Can the carrier just be pulled off? I am also sanding the sleeve to try and pull off the carrier.
jac
Post by jac » Tue Dec 13, 2005 7:28 pm
OK, removed the throw out bearing carrier. Now trying to get the cam out. To get the cam out I need to remove the cam rod which is connected by two ball joints. Have removed the nut that holds the top ball joint bolt to the rocker arm on the brake lever, but not enough room to clear the bolt from the rocker arm. Could pull the entire lever assembly out but the steering arm is pretty rusted to the shaft. Can the "ball" be removed from the ball joint? I loosened the two jam nuts at the ball joints but could not remove the ball from the either ball joint. Is there some other trick to remove the cam rod? Since everything is rusted, hard to tell what is correct method to remove this rod.
Post by Lavoy » Tue Dec 13, 2005 10:32 pm
If you have the throwout bearing carrier out, you should be able to slip the cam over the throwout tube.
jac
Post by jac » Wed Dec 14, 2005 7:29 am
Lavoy:
Thanks. Was able last night to get everything out. Tube was slightly out of round at the end so the cam was tight at the very end, but it came off. Was able to remove the rod after using penetrating oil to loosen up some rust. Everything looks usable with a little cleaning. Having taken one side apart, the other side should be much easier.
