Have a lead on a 350 parts machine. Will the six way blade, winch and log arch fit on a 1010?
Terry
350 parts on 1010?
townlineterry
Re: 350 parts on 1010?
Hey Terry,townlineterry wrote:Have a lead on a 350 parts machine. Will the six way blade, winch and log arch fit on a 1010?
Terry
If that won't work for you, I'm looking for a winch and log arch for the back of my 455D (backhoe removed). I *think* it may fit from a 350.
I am also in PA- Western side.
On the other side, if it won't work for you and you're still looking, I'll keep an eye out while I'm looking for one for mine.
PM me for my phone number if you want.
Thanks!
- JC
1985 JD 455D, 1970 450 crawler
- JD430C
- Contact:
HI terry, the winch will bolt up to a 1010, the only thing that might be a problem is the filter on the 3315 winch. i bolted a 10 series winch on a 350 with no problems. the 3600 log arch will bolt up to a 1010 if u have the 10 series winch or the 3310/3315 winch, i had one on a 1010 with a 10 series winch. I dont know about the 6way, been wondering that myself. I do know you would need to use 1010 inside blade brackets as 350s are different.
Andrew
Andrew
