1010 reverser question
RLAD
Post by RLAD » Sun Dec 04, 2005 10:30 am
My Dad just got a 1010C it seems to run good so far but, we do not have a operators manual with it . I have order one along with a shop manual on CD for 31.00 each from the local JD dealer it will take a few weeks to get here so he can't wait that long to get it rolling. So I have a few question if someone can help with the following. As far as I can tell it is a 1960 year model sn# 1113x. The shifter is on the dash and it has a reverser on the left. What does the reverser do and how does it operate? I see and have changed the oil filter along with the oil (JD 30 HD), but do not see a filter for the reverser where is it , where to put fluid and what type? I see only one hyd. oil tank and it is on the right side inside the frame next to the oil filter. Thank you for you help.
Ted
Post by Lavoy » Sun Dec 04, 2005 2:34 pm
To use the reverser, just pull the lever back and you will be going the other direction. It is a full hydraulic reverser as opposed to a clutch type reverser like on 430/440.
Reverser uses Hy-Gard, filter is on the RH side, you will need to unbolt a dorky looking casting to get at it.
RLAD
Post by RLAD » Sun Dec 04, 2005 2:58 pm
Thank you again for the reply. I will look at it and I am sure I will be getting some parts from you soon. Great web site. A lot of good info.
Ted
