Stripped bolts to clutch housing
The 7/8" x 3-1/2" bolts that go thru the frame and hold the clutch housing on my 450 are stripped or should I say the female threads they go into are. I tried a longer bolt in hopes of catching some thread but had no luck, does anyone know of any type of bolt maybe slightly larger that would be self tapping? or am I just better of to try to find a tap to fit, and hopefully not have to drop the housing.
go to your local parts store and buy some 7/8" inch helicoils, follow the instructions and they will will perform very well for you, be warned, once you helicoil a hole you should not run a tap through it. you can stack helicoils up in the same hole it just takes a little practice. if you wreck a helicoil, hook onto it with a pair of nedle nose vise grips and you should be able to pull it out by not turning them like you would if you were screwing in a thread, but by moving them in a circle motion without actually twisting them around.
1964 JD 4020
1974 JD 420B
1942 JD BR
1941 Cat D6
2008 Kubota B2320
1974 JD 420B
1942 JD BR
1941 Cat D6
2008 Kubota B2320
Users browsing this forum: No registered users and 174 guests
