1953 40c steering clutches
boler76
Post by boler76 » Fri Jun 12, 2009 5:52 pm
This unit has the 7 and 6 clutch pack, was wondering if someone can tell me what the total thickness of the pack should be, Mine looks in good shape but was slipping , Can a disc be added if more thickness is required Thanks
Post by Lavoy » Sat Jun 13, 2009 6:55 am
if it has 7 and 6, it has 420 clutch discs installed. Fibers are around .155, steels .093, so you can figure out the height, just multiply by the number of discs. If you can add a disc, the clutch is shot, and all the discs need replacing.
boler76
Post by boler76 » Sat Jun 13, 2009 1:55 pm
Thanks Lavoy for the measurements, according to that I am .121 short of full thickness , the steels are .90, do you think just fibres changed would be OK also what are the dimensions of the equalizer spring that goes in to the rear end to keep the axle from moving endwise, it is missing, Thanks
Post by Lavoy » Sat Jun 13, 2009 7:13 pm
Odd, if you are that far out, those fibers must have been in there a while. Yes, new fibers should bring you back up, steels sound fine if they are not rusted so bad they are weakened. You should also set the fingers on the pressure plate with the JD7 gauge once the clutch pack is reassembled.
boler76
53 40c final drive question
Post by boler76 » Sun Jun 14, 2009 12:36 pm
Does any one know the dimensions of the EQUALIZER spring, item 11 in parts book, that goes between the 2 shafts in the pinion housing? Mine is missing . Thanks
Post by Lavoy » Mon Jun 15, 2009 7:59 am
Sorry, missed that one. I think they are about an inch long give or take. I have them in stock if you need one.
rvbarkley
Post by rvbarkley » Wed Jun 17, 2009 4:31 am
Seems like I heard somewhere that it was either the same as or was a valve spring ??? Seems like mine was very similar.
Post by Lavoy » Wed Jun 17, 2009 9:55 am
I would have to have them side by side, but I think about half the length of a valve spring, maybe a little less diameter. It is not a real stiff spring, just keeps outward pressure on the drive shafts.
