i just wired up my jd 440icd. When i start the machine the meter shows that the generator is charging. but when i shut the machine off after only a minute of running, and then let it sit for a few minutes, the voltage regulator gets very hot. when i pull off one of the battery cables from the battery there is a small spark from the wire to the post.
what did i do wrong, i am scared to leave the battery cables on, as i think something is done wrong. the machine does not have a key switch, its wired direct, just press the start button and it work fine?
help
voltage regulator heating up
frozendozer
- 430 crawler
frozendozer
- 430 crawler
Users browsing this forum: No registered users and 83 guests
