lzrcqg
Post
by lzrcqg » Thu Nov 17, 2005 5:04 pm
I purchased this dozer for $500.00 and drove it onto the trailer. The guy can't get to run - the plug wires were on wrong. During overhaul he got the distributor in wrong causing the problem. It don't look like this - it was a major restoring project last winter. Three-quarters of the frame bolts and the blade mounting bolts were broken off. But the sheet metal was good, everything was there. I have put over 200 hours on this machine just this summer doing odd jobs and loaning it out to friends. Its the best stress relief around. Nothing like moving dirt. Would like to get a six-way blade for this dozer, any thoughts on that?
bent
Post
by bent » Fri Nov 18, 2005 9:01 am
Great looking machine! I had a 1010 with a power 6-way, they are a good thing. By far the nicest thing I found was the ability to change the angle right from your seat. The tilt was good when working with loose material but I found the crawler just isn't heavy enough to make it useful otherwise. I found the crawler would drift alot in hard ground. Also, it gives the crawler a little different look as the power 6-way is an inside frame mount.
Here is a picture
Brent
bighamlin
- 430 crawler
Post
by bighamlin » Fri Nov 18, 2005 8:54 pm
Really Nice!!! Sharp paint also. I hope my 1010 looks that good when I get done. Mine is a little different though, a Diesel with a 6way (612) and a ripper (35).
SmallTime
- 420 crawler
Post
by SmallTime » Sat Nov 19, 2005 3:25 am
Yea, I like it alot, looks good. Mines a 6way too, love to see a pict of your ripper setup and mount. Ive been wondering about building one that could also be used for skidding logs.
lzrcqg
Post
by lzrcqg » Mon Nov 21, 2005 6:25 pm
Thanks to all for the postive comments on my 1010. Thanks for the comments on the six-way blade. I would love to get my hands on a six-way blade for this 1010. Anyone want to sell? Or maybe a whole machine with the six-way blade? I got the bug for this yellow JD equipment.
- Site Admin
Post
by Lavoy » Mon Nov 21, 2005 8:39 pm
You had me worried when you were asking for just a blade, but you redeemed yourself when you asked about antoher crawler. If you have an excuse to get another one, take advantage of it.
lavoy
bighamlin
- 430 crawler
Post
by bighamlin » Sun Nov 27, 2005 4:37 pm
Here it goes, the first time I posted pics, hope they are sized right and don't take up to much space.
I got new shanks as shown, they are for a JD grader but are the same specs as the original ones that are no longer made. I still need to make the 1/2" keeper pins which should be easy.
The ripper is in good shape except I need to rebuild the cylinders and there is a crack I need to weld in two spots on the mounting plates.
Hope this helps "SmallTime"
Paul
bent
Post
by bent » Mon Nov 28, 2005 8:54 am
I like those heavy duty work boots the photographer has on!
Brent
bighamlin
- 430 crawler
Post
by bighamlin » Mon Nov 28, 2005 8:30 pm
Hey - this is Florida.
Daytime highs are still in the 80's. Nighttime lows may get down in the 40's in a few days though. Never get a chance to push snow around - sounds like a good excuse to have a dozer up north, more JD play time.
SmallTime
- 420 crawler
Post
by SmallTime » Tue Nov 29, 2005 5:18 am
Hey, thanks for the picts. I like the ripper, wish I had one. Looks like something buildable..........Ill have to think on this one
lzrcqg
Post
by lzrcqg » Wed Nov 30, 2005 8:09 pm
Thanks for these ripper pictures. A few questions on that ripper. What is the total width and what is the spacing of the shanks? Does the crawler handle it well or is tough going using a ripper? Boy, I wish I had one too. Nice additional to a crawler. And one more point; it is 20F degrees with snow falling in the thumb of Michigan.
bighamlin
- 430 crawler
Post
by bighamlin » Fri Dec 02, 2005 7:50 am
The total length of the tool bar is 48". There is a center hole, then one 12" to each side of that and then one 9 1/2" to each side of those, 5 positions total. You can run the shanks up to 15" deep. I only have 3 shanks, so I have never filled up all five to see how it pulls. In sand, you can put 3 shanks, probably no more, all the way down and pull ok on level ground. On a dry hardpacked clay road, forget about it, you could only go about 4-6". If you waited till about 2-3 days after a decent rain on the road, you can go down 12" on level ground.
lzrcqg
Post
by lzrcqg » Sun Dec 11, 2005 7:19 pm
Thanks for the measurments. Looks like a project over the Christmas break with my new MIG welder (early Christmas present). I'll let you know how it goes.
