440 clutch lubrication question
mgbuddydad
Post by mgbuddydad » Sun Apr 19, 2009 7:03 pm
Re-installling the throw out bearing assembly in a 440 gas. Should the carrier that slides on the clutch tube be packed with grease inside, and if so, what kind of grease ?
Grease from the zerk fitting only goes to bearing, possibly there is another path for grease to inside of carrier that is blocked. . . . . . ?
Hesitate to put grease this close to a clutch . . . .
Thanks,
Buddy
1959 440 IC
Post by Lavoy » Mon Apr 20, 2009 9:19 am
There should be a passage so that some grease gets on the tube as well as in the bearing.
mgbuddydad
Post by mgbuddydad » Mon Apr 20, 2009 7:17 pm
ok, thanks Lavoy, will find the hold and clear it.
Should I also pack the inside cavity of the carrier with grease ?
What kind of grease ?
Buddy
1959 440 IC
Post by Lavoy » Tue Apr 21, 2009 9:58 am
If you clean the hole out, it will grease itself. I usually put some anti-seize on them at assembly just to be safe, then the grease will take care of it after that.
Users browsing this forum: No registered users and 252 guests
