jd 450 OIL LEAK
bonesfixed
jd 450 OIL LEAK
Post by bonesfixed » Sat Apr 18, 2009 9:59 am
There is a small hole on the bottom of the dozer in the midline which leaks oil or hydraulic fluid. What is it?
CELSESSER
Post by CELSESSER » Sat Apr 18, 2009 1:39 pm
I would hazard a guess that you are looking at the hole in the belly pan for the oil pan drain plug.
The belly pan collects everything so that it runs down your arm when you are under there changing the oil!
Chuck
Users browsing this forum: No registered users and 190 guests
