Bi-Metallic or Fiber Disks
panicbutton
Post by panicbutton » Thu Apr 09, 2009 7:59 am
This summer I'm going to replace the steering clutches... Just wondering if the extra expense ($7-$10 per disk) for the Bi-metallic disks is worth the extra cost vs. the standard fiber disks.
Thanks-
'74 350B LGP, 179ci Diesel
Post by Tigerhaze » Thu Apr 09, 2009 8:55 am
Hi-
I know we discussed this in a few recent posts, so you may want to do a search.
I think the main advantage stated were that bi-metallic discs will not absorb moisture or oil like the fiber discs and thus are resistant to swelling which could cause a frozen clutch. This shouldn't be a big issue with regards to oil soaking if you are rebuilding since we presume you will replace seals and you are covering your machine to keep precipitation off of it.
However I think it was also stated it was an an advantage in moist, cool climates where moisture could condense regularly inside clutch housings.
Again you will want to search for those previous posts as my memory is sometimes fuzzy on those things.
Post by Lavoy » Thu Apr 09, 2009 10:44 am
IF you can do it for that price, absolutely.
jdemaris
Post by jdemaris » Thu Apr 09, 2009 6:26 pm
Tigerhaze wrote:Hi-
Allis Chalmers put self-venting drain-plugs in their small crawlers which I think was a great idea. Dry clutch crawlers often get stuck clutches just from condensation, as you mentioned. We tried leaving drain plugs out of some, but that is sort of a two-edged sword. They worked great until the crawler got driven through deep mud or a pond, and then got worse than ever. Same problem with John Deere winches. They tend to get wet, either oil, water, or both and then the clutches and brake gets ruined, or stuck. You're supposed to pull the drain plug once in awhile, but it usually never happens.
In regard to OEM, sometime in the middle of production, AC stopped using fibers and only put in the metallic in the small crawlers. I see now, that's all Deere sells for the 350s and 450s.
Eric.MacLeod
Post by Eric.MacLeod » Thu Apr 09, 2009 7:46 pm
hello,,is there metalic disc for the 420s or are they out of the question? thanks Eric..
Post by Lavoy » Thu Apr 09, 2009 9:29 pm
Yes, there is, but they are sometimes hard to find, and usually run about double of the fiber discs. From my experience, they are much more aggressive, and require more clutch (less brake) to work the best.
mikeintn
Post by mikeintn » Fri Apr 10, 2009 8:37 am
Where is the best place to buy the discs for a 350, go to Deere or are there aftermarkets ones that are cheaper, and are they as good.
Michael
Post by Lavoy » Fri Apr 10, 2009 9:24 am
I have discs on hand.
panicbutton
Post by panicbutton » Fri Apr 10, 2009 9:44 am
Lavoy wrote:I have discs on hand.
Metallics?
mikeintn
Post by mikeintn » Fri Apr 10, 2009 10:46 am
Is there a number I can call you sometime about parts Lavoy. Mike
Michael
CELSESSER
Post by CELSESSER » Fri Apr 10, 2009 4:20 pm
Lavoy's number is on the welcome page 701-361-1006
Send him a PM and he will get back to you in short order also.
Chuck
Post by Lavoy » Sat Apr 11, 2009 11:00 am
I don't keep metallics on hand, never really sell them. No problem to get them, I will be making a disc order shortly anyhow.
Post by digitup2 » Sat Apr 11, 2009 4:27 pm
I find that metallic clutches work more aggressively.I put some in a 450E and it really doesn't steer as nice as the one I had two years prior to it with standard steering clutch disks .They are better for a higher humidity environment yes that is true but they are a lot more aggressive in the steering department I found you don't get to feather the steering clutches the same with metallic disks. they are either engaged or they are not there is no in between it is different steering by far.If you don't need more abrupt and aggressive steering than put in the standard clutches and keep your housings as dry as possible .Digitup.
Post by digitup2 » Sat Apr 11, 2009 4:28 pm
panicbutton
Post by panicbutton » Sun Apr 12, 2009 4:17 pm
Would there be any harm in mixing the fiber and metallic? I was thinking that it would ease up on the harshness of just running straight metallics, and if any moisture did get in I would still have steering.
Users browsing this forum: No registered users and 199 guests
