350B wont move
350B wont move
I got my dozer home and the track wont turn, the engine is bad locked up, he said he drove it in the barn maybe 5 yrs. ago, it was missing then the engine lock, am I missing something even with the engine locked shound'nt it roll with the trans. in neutal, any ideas why it wont roll?
Michael
The B is a dry clutch I believe and you don't want to be spraying any oils on the clutch or breakband or you will be pulling the finals to replace the disks and breakband as once oil contaminated they will slip, especially when hot. If it is frozen that badly you may be in for a teardown just to get the linkages freed up anyway.
Chuck
Chuck
If you feel that you need to spray them down, use water instead of any oil or grease. Water is a good solvent and can do wonders on rust but not cause the contamination that causes slipping. It's still probably not good to saturate the fiber discs with anything, but better than oils. If you do, try and dry ut the clutch areas afterwards with a heater or something similar.
Users browsing this forum: No registered users and 246 guests
