As a relatively new user, this appears to be a very informative and professional site. It is my intention to find a good 350C 6-way with ROPS, somewhere in Eastern Canada or Northeastern U.S.A. Machinery Trader seems to be my primary research source. What is the width of such a regular-tracked machine? What would be the ideal trailer type and trailer size, ie., length, to haul this dozer using a GM 3/4 HD 4/x4 pickup?
Thanking you, Jim.
350C Dozer/corresponding trailer
Re: 350C Dozer/corresponding trailer
You're taking about a crawler that weighs around 10,500 lbs. and a trailer that will probably weigh over 3000 lbs. empty, and substantially more if it's a good one. You couldn't pay me enough to pull a 14,000 lbs. load with a 3/4 ton truck unless it was a short distance with no hills. 350C with dozer is 11 feet long, 7'7" tall with ROPS, and blade is 72" wide when straight or 65"when at an angle.jfischer wrote:As a relatively new user, this appears to be a very informative and professional site. It is my intention to find a good 350C 6-way with ROPS, somewhere in Eastern Canada or Northeastern U.S.A. Machinery Trader seems to be my primary research source. What is the width of such a regular-tracked machine? What would be the ideal trailer type and trailer size, ie., length, to haul this dozer using a GM 3/4 HD 4/x4 pickup?
Thanking you, Jim.
Nice to hear form someone as close as Walkerton.By Ontario regulations actually need a One ton to pull that 350 but for years my dad used a 3/4 ton for the job when he couldn't grab the float .I tryed givin him crap and he reminded me that I got cought with a 490D [13 plus ton]on a 12 ton float behind the old dumptruck .Just west of Monkton the MTO pulled me over and when I drove on the portable scales they shifted becouse of the short dubble axle on 12 ton trailers and the fact that the roadside had too much taper .They let me go while picking up the pieces of the wrecked scale .I always used the proper float after that There was a contractor that had a nice float on the other side of the bridge for his 400G.He parked it in there where that welding shop is Is he still in bussiness I think they called him Granny We don't do much work in that area but not far from you .Digitup.
Thanking everyone for the input
Thank you everyone for the info. I still intend to get that 350C and I will not be carting it around using the described truck as mentionned.
jmf.
jmf.
Now a word from the Peanut gallery. I hauled a 350B loader on a two axle flat behind a 3/4 ton pickup before, and had no problems at all. I don't have that particular trailer any more, but we got a new another one last year, pretty much same thing, 2-7000lb axles, tripod ramps, and it is used all the time for hauling crawlers including the above mentioned 350.
Users browsing this forum: No registered users and 233 guests
