gm deasil
- switchhappy
gm deasil
how do i see what motor i have.. im thaninking it is the 2-53, well thats what head gasket fit it, but the book shows a hand hole on the block and a vent tube, well mine dont have neather.. so is it mabe a 3-53?? what is the difference???
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
- switchhappy
ok mine is a 2 cylender, but i cant figure out why it dont have the hand hole on the side of tge block and why i cant find that air box drain tube?? my manual shows it by the dip stick on the left side/"if sitting on the crawler" ok my dip stick is on the right side with the blower?? tell me that one???
I have read somewhere that the inspection hole was deleted by GM during the time these engines were built. My parts manual PC-609 with date Jan-66 on pages 10-2 & 3 shows the cover was only used thru s/n 2D 4009. The drain tube apparently changes length at 2D 5160 from 14-3/8" to 2-7/16". It should be under/behind the govenor assembly on the left side of the engine if you were seated on the seat. I have yet to find the serial number on one of these engines. It is supposed to be on the right rear of the block (behind the blower??).
- BKahler
- Contact:
I have a late model 440ICD and mine had the short breather tube. Also I did manage to find the serial number but at the moment can't remember where I found it. Seems like it was in one of the top corners.
I vaguely recall mine having the inspection hole but I can't seem to locate a picture that shows it and the motor is about 600 miles away from me at the moment.
Here is a picture showing the breather tube:
Brad
Brad
- switchhappy
- switchhappy
found it.. thanks for the info mine was pluged off, the last owner put a pipe plug in it... but sad to say its blowing oil out that hole.. so my blower seals are shot.. how do i take this blower off so i can get it fixed.. or havesome fix it
Users browsing this forum: Google Adsense [Bot] and 28 guests
