440icd
- switchhappy
440icd
what causes the 440ice desail engine to kinda ack like it want to just spit and spudder then just rev all the way up like its gonna try n blow up>>?? could this be the rod that runs from the head down to the pump not adjusted right??? it does it worse when it is on the side of a hill..?? how can i fix this problem?? is something not adjusted right?? if anyone has a idea.. just let me know??? thanks
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
I JUST REBUILT A 2-53 FOR MY 440ICD. MINE ALSO WOULD REV LIKE IT WAS GOING TO BLOW, MINE HAD ALOT OF OIL BLOWBY AND I THOUHT I HAD A BROKE RING ONLY TO FIND TAHT MY CYLINDER HEAD WAS CRACKED. I HAVE FOUND A PLACE IN HOUSTON THAT HAS 4 NEW SURPLUS CYLINDER HEADS FOR THE 2-53,I WILL HAVE TO LOCATE THE NUMBER. THIS MAY NOT BE THE SAME PROBLEM ,BUT IT HAS SOLVED MINE FROM THE VERY HIGH REV. JIM
- Tractor 850
- 430 crawler
- switchhappy
crawler
i just had the head off this dozer and had the head checked and also put new head gasket on it, mabe it is sucking to much air, mabe i need to re-torque my head bolts, it dident start this untill i did the head gasket, i was thainking injector or mane the blower???
- switchhappy
- JD440ICD2006
There is something else about these engines that I have been told will also make them runaway. The only way to shut them down would be to close off the air intake. Seems like a seal or gasket blew out and it would start burning the oil in the crankcase, which is why the throttle lever is useless in trying to shut it down.
The later engines have a butter fly air shut off for that purpose, from what I am told.
Someone on here will know the details of this.
I believe you are referring to the blower seal- here is some info on it from previous threads:
http://www.jdcrawlers.com/messageboard/ ... lower+seal
- switchhappy
this vent tube, its on the blower side of the engine?? because iv never see one on the other exaust side?? mabe a picture would help me.. this sounds like what is wrong with mine.. im useing oil, but know he rings are good and head is good.. id say this is the problem.. also lavoy, can u get me the blower seals?? is there a update verson?? and how inthe world does this blow come off??
Users browsing this forum: No registered users and 356 guests
