350 3 pt.
PeterFroehlich
350 3 pt.
Post by PeterFroehlich » Wed Nov 02, 2005 7:23 am
This is the hitch/pto that I picked up with a bunch of other stuff at auction.
CCWKen
Post by CCWKen » Sun Nov 06, 2005 10:47 pm
Show Off! :lol: Nice find!
Is the PTO shaft splined? If so, what size and how many splines? Are there two bearings in the pto shaft housing?
JD420C, Ford 3910, IH 2606, Kenbota G32XKS
PeterFroehlich
Post by PeterFroehlich » Tue Nov 08, 2005 4:53 am
CCWKen, the trans. end of the shaft has 21 splines, and has a sleeve coupler on it, roughly the same dia. as the implement end. There is one bearing in the casting.
CCWKen
Post by CCWKen » Wed Nov 09, 2005 6:40 pm
Thanks Peter. I'll have to be making mine. :cry:
Post by Lavoy » Sun Nov 13, 2005 10:09 am
Ken,
What are you looking for as far as PTO?
CCWKen
Post by CCWKen » Mon Nov 14, 2005 11:42 pm
All I really need is the output shaft and housing. (I think) Am I correct in assuming that all I need to do is remove the "cap" and install the shaft/housing? The pto shifter is in place but I've never checked to see if it did anything yet. :shock:
I was surprised at the lengh of the shaft. (In Peter's pic) Too blurry to tell but is the long narrow part just a pilot? I was going to make a machined weldment for the bearing housing and make a shaft but I haven't been able to locate specs on the shaft. Just blury pictures and people that want to $ell the whole kit. :wink:
Post by Lavoy » Tue Nov 15, 2005 9:39 am
I forgot to ask, are you working on a 350? If so, the shaft in the pic is the right style.
