what size battery
roofdog
what size battery
Post by roofdog » Thu Feb 19, 2009 7:23 am
i can`t find in the manual what size battery to use in my jd 1010 gas,i forgot to take it out of the dozer before winter and its at the cabin 120 miles away,thanks in advance for the help.about how many cold cranking amps would i need for the JD 1010-4 cylinder gas
should of been a mechanic NOT a Roofer
Post by Lavoy » Thu Feb 19, 2009 9:36 am
A group 24 automotive battery will fit. I would get an 800CCA battery give or take.
roofdog
Post by roofdog » Thu Feb 19, 2009 10:51 am
thank you Lavoy
roofdog
Post by roofdog » Thu Feb 19, 2009 12:16 pm
that isn`t a deep cycle battery is it,thanks.
Post by Tigerhaze » Thu Feb 19, 2009 1:53 pm
Hi Roofdog-
Not to speak for Lavoy, but it probably wouldn't need to be a deep cycle battery as it would be continuously charged by either the generator or alternator, as long as those systems are working properly.
However I would suggest making sure the battery is of a tractor/ commercial/ industrial type as I believe they come with slightly stronger plates that can handle shock load/vibration a little better than a standard automotive or light truck battery at your auto parts store.
In any case, it always seems like my lead acid batteries last exactly two weeks after the warranty expires no matter how much preventive maintenance I do to them. :lol:
roofdog
Post by roofdog » Thu Feb 19, 2009 2:06 pm
thanks Tigerhaze,maybe i can get my JD running this year if i can get all my fixes together before i start working on it.
Users browsing this forum: No registered users and 671 guests
