1010 hydraulic pump specs
brettjones
Post by brettjones » Sat Feb 07, 2009 7:52 pm
I don't have my manuals handy and I'm trying to find the pressure and GPM specs for the hydraulic pump on the 1010c.
Thanks.
JD 1010c, outside blade, winch
Tiny Crawler
Post by Tiny Crawler » Sun Feb 08, 2009 10:15 am
Here are the specs from the service manual
13 gpm when operated at 2100 rpm and 1000 psi
brettjones
Post by brettjones » Sun Feb 08, 2009 10:40 am
thanks.
jdemaris
Re: 1010 hydraulic pump specs
Post by jdemaris » Sun Feb 08, 2009 11:03 am
brettjones wrote:I don't have my manuals handy and I'm trying to find the pressure and GPM specs for the hydraulic pump on the 1010c.
Thanks.
Depends. If equiped with a dozer and no aux. hydraulics it comes with a 13 GPM pump, i.e. 1.7 cubic inch displacement per revolution.
If it has aux. hydraulics and/or is a loader it uses a 23 GPM pump. i.e. 2.8 cubic inches per revolution.
Early pumps are Webster-Electric and later or replaced pumps are Cessnas. All use SAE-2 mounts. 13 GPM pumps have 3/4" splined shafts and 23 GPM pumps have 7/8" splined shafts.
System max. PSI is 2000 but pumps are rated at a max of 2500 PSI.
brettjones
Post by brettjones » Sun Feb 08, 2009 8:24 pm
So a 1963 vintage machine with an outside blade and a winch is likely to be the 13gpm Cessnas?
I asked because I'm considering using the hydraulic system to power a log splitter through some quick release fittings.
jdemaris
Post by jdemaris » Mon Feb 09, 2009 8:05 am
brettjones wrote:So a 1963 vintage machine with an outside blade and a winch is likely to be the 13gpm Cessnas?
It will pump around 6-7 GPMs with the engine running just above idle which will give plenty of speed for a log splitter with a 4" to 5" diameter cylinder.
You just have be very careful how you hook it up and use. It's easy to instantly blow the pump to pieces with one mistake. We had many brand new pumps come back that way.
If you already have an unused aux. port and valve, you're fine. If not and you're attempting to add, that's where the trouble comes in.
Jason Z in MO
Post by Jason Z in MO » Mon Feb 16, 2009 2:41 pm
John,
Would a 3-point / rockshaft on a dozer be considered an aux system and have the higher volume pump? I just bought a 1010 dozer with 3-point.
Thanks for all your help! Gonna make a book of your posts!
Jason
1010D D 6-way hydro blade w/ 3point, 1010D C/L, 350c C/L, JD B, JD 50, JD 520, JD 720LP, JD 4020, JD 4230
Post by Tigerhaze » Tue Feb 17, 2009 7:51 am
Hi Jason- I take it you found a 1010 dozer rather than the loader you were looking at? Give us the scoop on it if you get a chance...always interesting to hear about someone's new machine. The 3-point hitch is uncommon and would be a nice addition.
