the tracks on my 420 derail seemingly easy. have them tight to specs. of course if i`m into rock or tree stumps its a guarantee i will be running them off if i dont catch it right away. am i missing something? any tips or hints on tuneups to undercarriage or front idler wheel? yes, this old girl has alot of hours on it. not far away from needing new pins and bushings. my uncle that did all the maintenance though out the history of this 420 has passed away years ago, nobody else in the family remembers much of what the repair history was. dont know if the pins have been turned or not. i dont want to tighten the tracks past the specs. would it help to build up any parts of the the undercarriage by welding? and if i did, what type of rod do i use?
lavoy, direction reverser has been working great since rebuild.
thanks, Tim
tracks derail
tomcat4144
- 430 crawler
Tim,
Check underneath and make sure that none of the rollers have any flanges missing. Check front idlers for loose bushings.
I know a friend of mine fought this until I rebushed his rails, then it was cured. Turning will not help, all it does is shorten the track somewhat, but does not help the snake.
tomcat4144
- 430 crawler
Track derail
ok, will check them out soon as i get a chance. Thanks
Tim
Tim
