Paul45
- 430 crawler
Post
by Paul45 » Tue Dec 16, 2008 8:58 am
I have a 350 crawer/loader and there is alot of slop in the pins and bushings in the loader. looks like both the pins and the bushing are worn out.
What is the best way to fix this problem? is there a kit? how much $
Thanks for your input Paul
thanks Paul
350 track loader, 350 dozer
KenP
Post
by KenP » Tue Dec 16, 2008 2:24 pm
deleted
KenP on Thu May 16, 2013 6:20 am, edited 1 time in total.
Post
by digitup2 » Tue Dec 16, 2008 4:12 pm
If your pins aren't worn to much take a pin punch and mark the pins when you replace the pins put them in 180 degrees from where they were and you will get extra life from them .If they can be rotated that helps tighten things up sometimes as well .Digitup.
Users browsing this forum: No registered users and 254 guests
