440icd head bold toqur
- switchhappy
what is the spec on tighting the head bolts... how much do they get in ft-lb on a toq wrench
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
From the I&T shop manual JD-18 (for the 435D and 440ID [same engine]) "Beginning at the center and working toward ends of the cylinder head, torque hold-down cap screws to 170-180 Ft.-Lbs. in 1/2 turn increments." HTH
- JD440ICD2006
440 ICD torque numbers
I know of three manuals that have this info. The I & T that is mentioned above, the Detroit Diesel manual for the 53 series, and I think there is a JD version for the same engines (435, 440 ID, 440 ICD).
If you are rebuilding one (sounds like it), you may want one of those books as there are a number of torque values to have handy when putting her back together.
- switchhappy
head
no im not rebuilding.. i had a o-ring that was dry rotted and letting water into my oil.... i have it all together except the head bolts,,,, thanks for the specks on the bolts
- switchhappy
head
do i need any kind of thread sealer on the bolts... there shouldent be any water around them... i know to dip them in oil befor tighting... well at least thats how i do race motors...
