Clutch linkage problems
jdman123
Post by jdman123 » Sat Nov 08, 2008 10:13 pm
I was wondering if anyone has had any problems with the snap ring that holds the linkage that pushes the throwout bearing. It is a very small snap ring and I don't think it will stay on the shaft groove. has anyone tried any other methods to keep the ring from snapping off and having to break the dozer in half. I have had this happen twice and it did it under a heavy load then pressing the clutch knocks the snap ring off. Any help would be great!!!!
Shawn
430W, 420C 5 roller, H, MT, L
Post by Lavoy » Sun Nov 09, 2008 7:00 pm
If you mean the snap ring that is down on the clutch adjuster, yes I have. On a buddy's, I slid a flat washer on the shaft and welded it on, no more problem.
lavoy
jdman123
Post by jdman123 » Sun Nov 09, 2008 7:07 pm
Yes that's the one. Thanks for the tip. It should not come off that way!!
Shawn
Users browsing this forum: No registered users and 205 guests
