420 crawler engine overhaul
jd56420
Post by jd56420 » Thu Apr 14, 2005 7:31 am
I have a 1956 (serial # 86,1xx) jd 420 c that I is in bad need of an engine overhaul. I have a spare engine from a 1958 jd 420s that is a better candidate for the overhaul. Is there an difference between them(other than which side of the block the dipstick is located). Will the engine from the 58 420s hook up correctly with the 420c??
A question for Lavoy - Do you have a clutch discs and how much are they?
Are the clutches in a 420 crawler different than those in a 420 standard??
Post by Lavoy » Thu Apr 14, 2005 10:25 am
Engines will swap no problem, engine clutch kits are $200.
