sprockets
Eric.MacLeod
sprockets
Post by Eric.MacLeod » Fri Oct 31, 2008 2:42 pm
hello can anyone tell me the difference between casting number -m3088t and -casting number-m3098t, i cant quite read mine it looks like 3088, i have a chance to buy two that say 3098, the only problem is the track frames are welded solid so i need to keep the same spocket width, thanks ,,Eric
Lu47Dan
Post by Lu47Dan » Fri Oct 31, 2008 6:05 pm
This is what PC-505 says
T16261T ( - ) Sprocket , drive , 36" - 46" tread (sub for M3098T)
T16529T ( - ) Sprocket , drive , 38" - 44" tread ( sub for M3099T)
You need to figure out your tread width then use these numbers for reference .
Eric your 88 is probably a 98 . Hope this helps Dan
1956 420C with GSC blade
Eric.MacLeod
Post by Eric.MacLeod » Fri Oct 31, 2008 7:15 pm
thanks dan! when you say 34--36 is this the sprocket hieght? i laid a striaght edge on each sprocket and measured to axle flange and came up with two different specs one was 3.5 inches one was 3.25, is this right or is it because one is worn? i have a chance to buy two used sprockets just want to make sure they fit and dont want to hold owner up to long,,thanks..Eric
Lu47Dan
Post by Lu47Dan » Fri Oct 31, 2008 10:14 pm
Eric,
Tread width is what determines which sprocket your crawler used . Tread width is defined as the distance between the center one sprocket to the center of the other sprocket . The way I checked mine was to measure from the outside edge of one sprocket to the inside edge of the other sprocket . The M3098 sprockets could be flipped inside to outside to narrow the tread width to 36" that would be with the Concave part of the sprocket pointing in towards the final drive , or 46" tread width with the concave part of the sprocket pointing out away from the final drive . The M3099T sprockets had the given range of 34" to 44" . The flange to face of the sprocket measurement I do not have at the moment as I have not seen it in the service manual as of yet . The difference in the measurements could be from wear and tear on the sprockets . To check that measure across the root of one of the gullets? (the space were the pin engages the sprocket) on both sprockets that will tell you if you have a lot of wear to the sides of the sprocket .
Since your track carrier frames are welded to the cross members you do need to confirm the tread width and casting numbers before buying two new (used) ones . Put the sprockets back one and make the measurements to confirm their identity . Hope this explains the tread width for you . Dan
Dave Seager
Tread width
Post by Dave Seager » Sat Nov 01, 2008 5:32 pm
Lu47Dan wrote:This is what PC-505 says
T16529T ( - ) Sprocket , drive , 34" - 44" tread ( sub for M3099T)
:?: Question!?!? can you double check your tread width specs please? It would seem to me that they MIGHT be 36" - 44" and 34" - 46" (deeper dish will move the tread width more in EITHER direction)! :o
Thanks, Dave 8)
Lu47Dan
Post by Lu47Dan » Sun Nov 02, 2008 11:13 pm
Dave , the 34" should be 38" I have corrected it , see what I get for posting when I am sick . Dan
Eric.MacLeod
Post by Eric.MacLeod » Mon Nov 03, 2008 4:17 pm
dan i measured the sprockets like you said, they were about 46.5" some wear would acount for the extra half inch, thank you for the info, i really needed it. you was right my 88 was a 98, Eric
Lu47Dan
Post by Lu47Dan » Tue Nov 04, 2008 10:22 pm
Eric , you are welcome , thats what we are here for . Dan
Users browsing this forum: Google Adsense [Bot] and 28 guests
