2010 steering clutch drive shaft
Ron
Post by Ron » Fri Oct 14, 2005 12:12 pm
JD 2010C-----Does the steering clutch drive shaft (from the ring and pinion) pull out thru the center of the clutch from the outside of the tractor?
2010OWNER
Post by 2010OWNER » Mon Nov 07, 2005 12:37 am
Hi Ron,
You've probably already got it out, but yes it does pull out through the clutch.
You may have to use a slide hammer. It can be a little stiff.
Brian
Users browsing this forum: No registered users and 53 guests
