555b Lost a track
555b Lost a track
Hello to all , I am glad I found this forum. Track spun off of my 555 and have been looking for info on the best way to get it back on. The manual tells me I need a 50 ton press to remove the link. Is this true? Its stuck in a difficult spot so it makes matters even worse. I have been told I can loosen bolt next to grease fitting and relieve tension on adjuster to get it back on. I did that but tension is still there. Any advice/help would be greatly appreciated. I believe it to be 1986-1989.
- Paul Buhler
Hi: Does it have a backhoe or winch on it? ROPS?
The goal is to try and get troublesome side up in the air so that you can spin that track without moving the machine, and gain slack. Sometimes you can build cribbing and use the bucket or blade to lift the front; use the backhoe to lift the rear, or if you have a ROPS and winch, maybe you can go around a tree and hook to the ROPS and get some leverage for lift that way. Once there is a clearer picture of your problem, you may be able to walk the track back on using a long prybar/crowbar and another person holding a steering lever and slowly rotating the track forward or back - whichever makes sense. I'd take all the grease out of your adjuster to gain as much slack as possible too. Be careful sometimes the track snaps back on and the prybar wants to take you for a ride. Good luck. Paul
Users browsing this forum: No registered users and 274 guests
